Cubase/Juno DS
Hi, I'm trying to use Juno DS midi sound recording with Cubase, actually is just able to wor controlling Halion, I need how to get this done using the DS as a MIDI device or a VST. Kind of tricky since I was using a Yamaha S90 which is like built for that program but with the Juno, it looks little different. Thanks.
Cakewalk uses INS files (Instrument Definitions) to control instruments in the DAW. Anvil studio uses these same files.
Cubase uses its own system but you may be able to find a conversion utility.
Here's a Juno DS INS file. Hopefully you can make use of it. Worst case scenario you can open it in notepad, it's a plain text file and copy and paste to Cubase.
  • Roland-Juno-DS-ins.zip
I know it applies to the MIDI keyboard. I have no idea about the VST. I don't use VSTi's.
tfmc369
