Roland patch script file for Cubase of Roland fp-90
I'm looking for a patch script file for cubase for piano keyboard Roland fp-90.
Someone knows if it exists and where I can find it?
Thanks
You can ask over at Roland Clan Forums...
http://forums.rolandclan.com/
And in case you come across a Cakewalk INS file that does the same thing here's a link to a Cakewalk INS to Cubase Patch Script Converter that may do the job for you.
http://forum.cakewalk.com/Cubase-Instrument-Definitions-How-To-m3712317.aspx
And worst case scenario if you can't find anything you can always start with a Patch Script for an earlier, similar model and edit it to create your own.
I've done this a few times in the past to create my own for Cakewalk.
