Firmware Problem With Juno DS88
Hi all,
As you all know I own a Juno DS88 that I traded for a DS61 plus cash.
When the DS88 arrived it had firmware 1.06 which I flashed to the latest 2.10
The problem is, this firmware breaks the generic USB Class Compliant Driver built into the board.
On the DS61 I was running 2.00 with no problems.
Here's my dilemma. I would like to downgrade the firmware to 2.00 but Roland has removed it from their website.
Since I am not the original owner Roland won't open a ticket for me so I posted on Rolandclan where someone else has added it to an existing ticket.
Here's what I am asking. If anyone out there has the original file of the DS88 firmware V2.00 could you please msg me for my email address and email it to me so I can downgrade?
This would be a lifesaver as it no longer functions with my Linux machine without this built in driver.
Thanks in advance.
Sorry about your problem, have you looked in the Roland website in amongst the Legacy items? I hope you can access this but no doubt different countries will see different parts of said website.
I have just looked and found a zip file, its called juno_ds_sys_v106.zip
I have downloaded it and can email it to you if you cannot access the Legacy part of the Roland website.
Problem solved.
It required a factory reset on top of a simple reboot.
The directions stated that all that was necessary was a reboot.
All's well that ends well :)
Problem solved.
I was going to say . . You are not allowed to have technical problems! You are the fixer of problems! We all rely on you!
Now you reminded me of the doctor who had a virus! Doctors do not get sick!
But thank goodness you did not let us down!
Not only do you fix eveyone elses problems . . you even fix your own!
good work (as usual)
Ray:)
Heh :) Thanks Ray. Actually I feel a bit sheepish about raising the roof before trying the same advice that I give to everyone else :p
It backs up the patches and user settings to a thumb drive so I easily restored those after the factory reset.
Either the original owner had some funky settings in there or else it just went berserk after the flash.
Either way I used my backup from the DS61 to restore.
It's playing like it should now.
Happy Happy!!! :D :D :D
I've been using Linux as my primary operating system longer than most millennials have been alive.
I'm not switching back to Micro$haft anytime soon :p
