FP E50 using App
Do I need both Bluetooth connections, midi and piano?
Accompaniment selection but nothing happening when start?
I’m not seeing any tones when in piano settings on app?
Thanks
The App gets terrible reviews.
The App will need to pair with the e50 if you have not already done so, P31 of the manual shows how.
If you have done this check on your mobile device that Bluetooth is seeing the e50.
If it is seeing it OK but you are still having problems I suggest you try a direct USB connection and see if the App works better that way.
If still no luck, contact Roland Support.
Limeydog
