Thanks Mourndark! Ill look into my settings a little more. I have a good setup, so I dont think its the actual COMPUTER hardware, may be my configuration or my ASIO Setup (which is a TonePort UX2 handing it, since I have a crappy built in sound card that has horrible latency)
I Just want to use my keyboard to send the actual midi notes. But I would like to be able to change the VST and VST parameters from my keyboard instead of having to stop, go to my computer and change the VST instrument. After reading the manual, I THINK my keyboard may support what I want to do.
Do you think you or someone else could try to help me out (or point me in the right direction?)
I researched and found that what I want to do is probably called Quick Controls in Cubase. I click Learn, press the keyboard button I want to use to do my function...
http://www.crewxp.com/ewql1.JPG
then I go to the Quick Controls box and select what I want it to do. (Confused on this part). Im using the EWQL Orchestra VST to control some Double Bass and a Violin. Quick Controls lists numbers 0-511 in the EWQL category. I have no idea how to find what number does what I want it to do. All I really want to do is switch from one MIDI VST Instrument to another.
Anywho, my EWQL VST looks like this:
http://www.crewxp.com/ewql2.JPG
In the EWQL Quick Control folder (not even sure if what I need is in here), I found that 0 is Volume, 1 is Pan, 2 is tuning, etc. But the setting to switch Instruments may not be EWQL related, but Cunbase?
My VST Manual:
http://www.crewxp.com/ewql0.JPG
My Keyboard Manual:
Thanks for the replies, heading to bed, I will read your (Tweak)'s guide when Im at work tomorrow and post back tomorrow. Just wanted to provide a bit more info in the mean time in case someone knows the answer.
I researched and found that what I want to do is probably called Quick Controls in Cubase. I click Learn, press the keyboard button I want to use to do my function...(Im using EWQL as a test, but I would like to be able to switch from EWQL instrument to Alicia Keys to The Grand with a press if possible)
My VST Manual:
http://www.gearslutz.com/board/atta...ng-vi-suggestions-.complete.guide..ewqlso.pdf
My Keyboard Manual:
http://www.yamaha.com/yamahavgn/Documents/psre413_es_om_a0.pdf
I know its a lot of info, I'm just trying to explain it, but this might be a simple know how for most of you guys. Once I can get this down and the skipping problem fixed, I can actually start recording my ideas on computer rather than my iPhone's Voice recorder!! Cant wait!
