Help with Technics KN1000
I've just bought one of these second hand and whilst I've found it pretty easy to pick up, one thing is driving me mad and I can't find the answer in the manual or elsewhere.
If I'm just using Poly1 and/or Poly2, all is fine. However depending on the sounds selected, if I then add bass as well, some of the poly sounds go down an octave. If all did it, it wouldn't be a problem, I'd just play the right hand an octave higher. I cannot find any way of controlling this.
It seems to be organ sounds in the main that do this.
Does anyone know how to resolve this ?
Hi! Have an Technics KN 1000, it has been not used for many years, so some of the tast does not work, some times, they do, and then they dont...??? can some tell me what to do, to reset it?
Did read another question here, tried that , didnt work....
sfz5
