I can't seem to get my Alesis Nanosynth to work with my DD7
Hello All,
I have two questions. I can't seem to get my Alesis Nanosynth to work with my Boss DD7 delay pedal. I have to use a sterio cable that goes to an 1/8" out which uses a 1/4" adapter. I plugged this in to my DD7 and the DD7 doesn't respond with anything. The DD7 has worked with everything I've used why doesn't this work?
Also, I have an Axiom 61 MIDI controller to use my Alesis. How do I access all of the 640 sounds using the MIDI controller? The Axiom always seems to get stuck on one sound and I can't do anything to the Alesis or the Axiom to change it. Why?
Any advice would be wonderful. Thank you.
Roxyamused
Thanks but I figured out the problem. The adapter I am using to plug into the pedal is a stereo to stereo adapter when I need a stereo to mono adapter. So I just plugged my synth into my mixer which bypassed the problem.
Thanks again,
Roxyamused
