I am looking for a program that allows you to see at a glance which instruments are used in a midi file. Does anyone know such a program?
Yes and no.I am looking for a program that allows you to see at a glance which instruments are used in a midi file. Does anyone know such a program?
I’m sure Busker by JM Software can show you the instruments used. ( MS Windows only). Download for a free trial http://www.1manband.nl/busker/I am looking for a program that allows you to see at a glance which instruments are used in a midi file. Does anyone know such a program?
