Keyboard for my wife (Valentine's Day)
KC, MO
We live in a small 2 bedroom home. Our son has the piano my wife used to "plink" on before we moved.
She really misses her keyboard time.
The space I have available is about 13 inches wide and 36 inches long.
Can you recommend something that will work for her?
Thank you,
Lucky Husband
Would you and your wife mind getting an electric piano?
If so, then I'd recommend the Yamaha CP-70B Electric Grand Piano.
KC, MO
I'd like a small-inexpensive-keyboard; that sounds like a piano.
My wife and I are 64. I play the harmonica. Neither of us wants anything technocomplicated.
Thanks, again!
Ohio
One of the best inexpensive, piano sounding keyboards that is also not very complicated would be the Casio PX130. Not sure if it's less than 36 inches long but it might be close. You might be able to pick one up used and even save some more money.
If a PX-130 is beyond your budget, try a CDP-100. An older version of the Privia but cheaper and pretty comparable. $200-250 on ebay and worth every penny.
