Keyboards like the Akai Advance?
I'm looking for other keyboards similar to the Akai Advance series.The features I want: Can hold just as much or almost as much presets, easy to use preset explorer like on the Advance (Sorts all the presets into the VST plugins), works with all VST's, works with FL studio, has pads that do the same (can assign sounds to each of them like banks, and can enable them or disable them to mix up multiple presets for performances), and knobs to control parameters. Its a lot to ask on a keyboard, but I'm looking for other choices than just the Advance 49.
sfz5
