KN 7000 / SD Card.
Hi all I have just purchased a 7000 and when I insert the SD Card it says no SD card In machine. Can I copy MP3 to an SD card and then play along to it........Thanks.
England
Hi Shezza firstly make sure that yours is an SD Card and not an SDHC card as they don't work. Secondly if its a new SD Card you may have to Format the SD Card from within the KN7000 before you can use it. Thirdly no you cannot just copy an MP3 to an SD Card and it will play. You have to use a bit of software on your computer called SD Jukebox Ver2 which comes with the keyboard. Far easier to use midi files and the quality of sound is just as good as an MP3.
Staff online
JCGlines
