Korg Triton Taktile
Hi there, thanks for having me
Trying to set up my 49 key Triton Taktile with Cubase 10 Elements
But alas, cannot seem to find the correct driver
I've downloaded the one's that google has presented and they haven't worked!
My Akai MPK mini works straight out of the box
Any ideas?
Thanks,
Pete
I should say I particularly want to do this because the Akai has two broken keys!
Welcome
Have you downloaded the correct Driver for the version of Windows you are using?
The Driver for Windows 10 is not compatible with Windows 7 & 8
Hi Biggles,
Yeah I have, but it doesn't seem to show up on Cubase. I will try again now
I think now I should try uninstalling and then reinstalling the driver
You also may need to install Korg Kontrol and to have it running on your PC before you power up your keyboard.
Check your manual for this.
Have downloaded 'Configure KORG USB-midi driver' but it doesn't seem to work
and have looked at the manual but no mention of Korg Kontrol
Have also tried Restarting my computer
Bit stumped, I lent the Triton out and maybe it's got damaged
Hi Biggles,
That doesn't seem to have worked either. Not to worry, I've got another midi keyboard
Gianni65
