Kurzweil MPS10 key dynamics problem
Hi everyone!
I just got my hands on an old Kurzweil MPS10 piano and found out that it has a small problem - the dynamics on one of the keys is malfunctioning and always stays on the highest point - only if I push the key very very lightly it sounds OK. If I push it a little bit harder it goes to max and sounds a bit louder than the other keys.
On all presets where no dynamic touch is required/set (organ for example) the key sounds normal and equal to the others...
Anyone knows how the dynamics are handled mechanically - is there a sensor or something similar to be cleaned/repaired/replaced to make it sound normal again?
Thanks in advance for your help!
sfz5
