Kurzweil pc88 issue
Back up your settings, then unplug all pedals and other connectors except for line out and do a factory reset.
If the problem persists it's a hardware failure.
Manuals are available for download here.
Just download and print them out and read thru to learn how to backup settings and do a factory reset.
May seem a stupid question but bear with me
Do you play and listen using headphones or using the inbuilt amplifier and speakers?
If you use headphones check them out and if you have removed them do make sure that you have not left a small adaptor in the headphones socket.
sfz5
