Looping with multiple synths
Hi,
I own 7 keyboards at present.
I want to use a loop pedal with these synths.
Is there a way to get a loop pedal working to get 8 outputs from the loop pedal into my interface then software (logic pro x)?
Would I need to buy multiple loop pedals and how many would solve this problem?
Is there any other way of solving this problem?
I understand this may be difficult to achieve but I would appreciate any input.
Thanks
Fred Coulter
Central Florida
What kind of mixer do you have for the keyboards? Does it have an effects send and receive? That's what I would use in your circumstance.
As for multiple pedals, I'm having problems imagining them staying synced together. But perhaps that's what you're looking for.
sfz5
