Midi
Ik ben een beginnende toetsenist, ik zou graag willen vragen hoe je meespeelt met een midi-les, moet je instellingen wijzigen of hoe doe je dat?
alvast bedankt
I use Google translate all the time. Anyway, do you know if I create a new sample will I lose forever the original smpls that came with my E-473 Yamaha? I have tried saving the originals but save SMPL -> press enter "No data" Does that mean if I create a new sample I will lose the originals forever?
No, you can always restore the built-in default samples. See page 45 of the owner's manual for information.
Hehe, I like trying things out but not if it is going to spoil things. Thank you. More knowledge and things to try. Thank you for your support, John
Gianni65
