Mute layers
Hi there. Does anyone know an easy way to mute/unmute layers in a studio on an FA08 set for live performance. E.G bring up an organ on top of a piano etc
I'm not familiar with the FA08, but on my Yamaha models it would be a simple matter of selecting the Main and Dual voices, then just toggling Dual On or Dual Off.
Many thanks.I,ll give it a try. Also I found by highlighting that certain layer I can adjust the volume with a dial,which will do the job.
