Pedal Light Bulb Replacement
I just purchased a used (but like new) Technics SX-F100 organ. The pedal light bulb is burned out. Does anyone know what type bulb this is? Volts, wattage and replacement number of bulb.
Thanks so much!
Mike
Technics SX-F100 Americana Series
If there's a lighting and electrical shop in your area, remove the bulb and take it to them. The part number should be written somewhere on the bulb itself, but even if it isn't those guys will be able to just look at it and recommend a replacement.
drummerguycf
