Please help to select Keyboard: Yamaha PSR-S650 vs PSR-EW400
Rio
I can't decide which one is best to buy between the Yamaha PSR-S650 vs PSR-EW400. I can buy one of these for the same price....
The EW400 has one more octave than the S650.
The S650 is a workstation. The EW400 is an entry model.
The S650 is now superseded so i would suggest it is second hand.
Take all the relative precautions when buying used.
The choice between the two depends on what you want to do with it. They are both quite different.
Rio
thank you very much. Wan't to buy one of these to play some simple songs with rhythm and want to learn to play better with online tutorials.
sfz5
