Portable Sampler Vocoder Synth/Keyboard
Hey everyone,
I'm about to get a Korg Minilogue but I really want a small synth to take with me too. I travel a lot by train and I'd like to just sit down and play around with it.
I want a keyboard/synth that runs on batteries where you can record small samples with and pitch them and also be able to use it as a vocoder, does this even exist?
Thank you for the help ;)
There are a few small synths with vocoders. None that I know of that double as samplers. Add to that battery operation and you get a short list.
Check out the Microkorg, the Novation Ultranova and Novation Mininova and the Roland JD-Xi.
Some of these run on batteries, and some I am not sure of.
Anyway, these are the most likely suspects for what you are seeking.
http://us.novationmusic.com/synths/mininova#
http://global.novationmusic.com/synths/ultranova#
http://www.korg.com/caen/products/synthesizers/microkorg/
https://www.roland.com/global/products/jd-xi/specifications/
Microkorg is the only one of the 4 that runs on batteries.
BTW, the two Novations CAN be powere by USB so you could power them with a laptop.
sfz5
