Power reset
I am new here....I have a Casio keyboard... my problem is when i take a break for just a short/few minutes it will reset and i keep on resetting it every time I play it.....thanks for your help
Might have auto power off mode enabled, meaning it senses inactivity and times out and powers off automatically. This is some sort of requirement in certain countries. Since you didn't indicate which model of Casio it's hard to say if that is the issue or not.
First thing to do, if you haven't already - is bank your presets. That way if the keyboard does turn off because of inactivity, it would only take powering it up again, and pressing one bank button to load a preset. There is an auto power off - check your manual for where it is located. It is probably set at the shortest interval (5 minutes) - scroll it to 1 hour, or turn it off.
yyz
