RD-88 System Exclusive Message
Hi everyone, I have been gravitating unconsciously towards Roland it seems.
I Just Got me an RD-88 to use with Ableton.
I really need help sending the right System Exclusive Message to change the Keyboard upper range.
I is described in the midi manual on page 22, but i just can't get it!!
I got this one to work for fine tuning: F0, 7F, 7F, 04, 03, 00, 2C, F7.
No luck yet with the other one. Can anyone help me with this?
Thanks in advance
Are you trying to send the SysEx message to or from Ableton Live? As far as I know, Ableton Live does not support SysEx messages of any kind-- SysEx messages are filtered out when you send MIDI to Ableton Live or load/import MIDI files, and there is no provision for adding or editing SysEx messages within Ableton Live.
However, you might be able to use a third-party plugin to set up SysEx messages and send them. Cockos (makers of REAPER) have a set of free plugins (ReaPlugs) that includes a MIDI plugin (ReaControlMIDI) with SysEx support:
If you're already using some other third-party plugin to utilize and send SysEx messages from within Ableton Live, what plugin is it?
