Roland FA-08 - Import A sound created in Logic X
I have been trying to duplicate a certain sound I need on the FA-08 and have not been able to get it to where I want it. I have created it rather perfectly and quickly in the Retro Synth plug-in in Logic X.
Is there a way to load it as a sample or something into the FA? I would hate to have to drag around my computer to live shows for just one sound. Any advice would be appreciated.
Probably not. You can load 16 samples into the FA which can be played from the pads, and there is also a way to play them from keys, but just those exact 16 samples, they can't be stretched to other keys to make a completely keyboard-playable sound. If you have an iPhone or iPad, though, you can lod complete keyboard-playable samples there, and then trigger them from the FA.
