Roland VR 730 sounds
Hi all, I am trying to find an arpeggiator on the VR730, but can’t ?
Also looking for a repeat / tremolo sound to get as close as I can to Pete Townsend’s “ won’t get fooled again”
Any helpful tips greatly appreciated, thanks.
There's no arpeggiator. Sometimes similar things can be done with the looper and rhythm pattern features, though.
For the repeat effect, use the Slicer MFX.
It looks like there are a few Multi-Effect types that might help-- Tempo Step Phaser (I'm not sure about this one, but it sounds like something I'd want to check out), Tremolo 1 or Tremolo 2, and Tempo Slicer.
You might also get some interesting results using one of the Delay types, perhaps in combination with one of the Multi-Effect types suggested above.
As for an arpeggiator, if you can connect to an iPad then perhaps there's an app for that?
