Sustain pedal on FP60X doesnt work while recording
heh
I have a FP60X, and i run into a problem when recording: I want to replay a recorded track and play on the same time. This works, but the sustain pedal doesn’t work… Is this a bug or a feature? Can’t find anything about it in the manual.
If you are using a built in sequencer that records the sustain pedal as well, then it may be locking out the live pedal intentionally.
It might be configurable or it might not.
Check your manual.
