TECHNICS KN6000 MIDI PROBLEM
My KN6000 midi will not play my recordings from my floppy disk. I haven't played this keyboard in a long time. The keyboard works well but the midi after loading the disk won't play it when I press the "Start/Stop" button. There is nothing wrong with the floppy disk recordings, as I tested them on my KN2000 midi. I have always in the past been able to record, load and play from the KN6000 midi. I do not have the keyboard hooked up to my computer, by the way.
1. What could be the reason for it not playing the disk?
2. If I find another midi to buy, is it difficult installing a new?
3. Who works on Technics keyboards?
Thanks for any help you might be able to render!
Zolder.B
reason for not playing the disk
Drums level volume is set to min
Sequencer play button on
clock is set to midi
check it out
drummerguycf
