Upgrading a keyboard after 7 years of playing
This is my first post here on this forum so Hello to everyone.
I've been playing keyboard since 2012 and I'm thinking of upgrading my instrument.
I was learning for my own and at the moment I am familiar with basic chords and some basic scales what allows me to play majority of popular songs on the basis of chord lists. I am also familiar with basics of musical notation, but I strongly prefer to play by chords or by ear. For some time I was playing with my friend's band and I played on stage twice.
What I find tough is improvising and feeling free playing, I mean I lack the ability of playing something original, something own.
What I have now is Yamaha YPT-220 keyboard. I'm thinking about upgrading to Nord Electro of any generation. What do you think?
Welcome.
The sales guy at my local music store was on a high when I last went in, he had just been playing for the first time a Nord piano 4.
Me I would rather have the Stage 3 which I played a few months ago and loved it.
The Electro does get good reviews so if that is what you fancy then why not.
Its a case of deciding which variant to go for.
Worth going to a music store and playing as manydifferent keyboards as you can within your price range as it will give you an idea of what else is available.
I also suggest that you have a serious look at a Roland Juno DS 88, OK it may not look as good by a long way as a Nord but they sound and play very well indeed plus they are cheaper than a Nord.
There are so many boards to choose from, what drew you to the Electro?
Electro's strengths are pianos and organs (though only Electro 3 and up are strong on acoustic pianos).
If you are going to go the Electro route I would recommend no older than the Electro 3. With the 3 you can use different instruments from the Nord Library and have choices of different acoustic pianos. With the original Electro and Electro 2 you cannot load in different pianos. The Electro 3 also has the Nord C1 equivalent organ which is a step up from the original and E2. the Original Nord and E2 technology are rather old, even the Electro 3 is 10 years old but I think you'll find the couple of hundred dollars cost difference between the E2 and E3 are worth it. Keep in mind that all Electro's prior to the Electro 5 are mono timbral, meaning you can only play one sound at a time, i.e. piano, organ, EP, clav, etc.. you can't play piano and organ at the same time. If you need this convenience then you are now in Electro 5 territory.....
Again the question though - why the Electro?
You need to ask:
Do I want to play PIANO/EPs, or ORGAN, or SYNTH primarily.
If its piano - you want a weighted board - the Nord Piano or stage 3 88 - IF you go Nord, but there are a lot of others out there.
If its organ you really want a waterfall keybed - the Nord Electros have these as do teh Roland VRs
if its synth - then pick a synth or workstation. The Nords are not great here - unless you go for a Lead (4 or A1) as a synth. They dont have a workstation really.
If you want a combo of them all, you need to prioritise the sounds and keybed you want. IMO non of the Nords are great all rounders. Only the Stage has a decent synth - and its decent but thats all really - and orchestral sounds are week.
Next question - whats your budget. That will give some indication of what you can go for that fits the answer to Q1.
Ultimately, if your on budget - Id stay clear of Nords. They are great at what they do - but come at a price premium. You can get something almost as good - and possible better (depending on your needs) for a lot less.
Not being condesending, it sounds like Nord maybe a little expensive for your ability level. They make many good keyboards for half the price. I have a Nord, a Kurzweil and a Roland. The first two have weighted keys the Roland does not.
I love it when they post a question then burn a bunch of people's time trying to help them and never respond or return.
sfz5
