Hi could you finally undertand wich are the midi messages that can be control with the knobs?Thanks for your quick reply. After posting in the forum,I re-read the manuals and get clear that the sliders are fixed to the labeled functions, but the knobs can be set to modulation duties, how, is not that clear. By the way the Controller numbers are from the standard Midi Continuous Controllers List, I used to have a Midi CCs List translated to earthling,must be somewhere in the hard drive. Well, the synth will be in my hands in a couple of weeks, so... I guess a big dive in the pdf dark lagoon awaits for me,there on the horizon. Thanks a lot.
Still a good question. I started down that rabbit hole, but jumped out of it shortly thereafter, I kind gave up. BUT, I did find some stuff that might get you going.Hi could you finally undertand wich are the midi messages that can be control with the knobs?
I want to control the volumen of each pacth of a performance mode, but up to know seems that only the to volumen slides con be use
