Volume pedal
Quebec,Canada
Hi, can save my set up of the expression pedal volume
Every time I open the kn7000 I have to restait agaiin the confédération
Thsnk you
Posting the same question twice just pisses people off.
If anyone has an answer it could take years to get back to you.
Be patient.
And I don't think it's doable unless you can save it as a performance/registration/favorite, whatever the hell technics calls it :p
Quebec,Canada
First my first post the writing was no good so thats why I wrote it again
I am french ,sorry if I offend you
I had a few kn7000 since 2003
There is nothing in the manual how to save the set up off the expression pedal
Only to sat up has total expression or part set up
I don't really understand the question?
You want to save a volume pedal setting?
The volume of a pedal is always where you left it last.
If you want to save it in your configuration, then
A) it might be a dead battery
OR
B) It never had that feature in the first place.
Read your manual CAREFULLY. It's probably a single phrase that tells you if you can do it or not.
Look for any reference to non volatile memory
England
Answer is as follows:
Program Menus buttton
Control Button on screen
Foot Controllers button on screen.
then save whatever you are doing to SD Card
JCGlines
