- Joined
- Nov 27, 2022
- Messages
- 11
- Reaction score
- 2
Thank you.You paid top dollar for a pro board. Maybe that was not the best choice at the moment. If you need extra features then you need to change your target and find a different instrument or buy external speakers, which means more spending. Now, you need to consider you have a really good sounding board at hand. No pro board or stage piano will have speakers. On the other hand, digital piano technology has dropped in price and now is very affordable. If you still want speakers and bluetooth you should try Williams brand. They very cheap and full of features with really great sound. When I say cheap I mean low cost. There are many brands and all of them have Home Digital pianos, which is the kind of instrument you are describing for your needs. For less than1K you can get a solid package with many things included. When it comes to pianos it is always best to try it personally but f you can't just refer to the reviews from all buyers at big seller like Musicians Friend, Sweetwater music, Sam Ash, etc, etc. Good luck.
