wk 7600 ...polarity for foot pedal...
..just got a 7600...
Is there any way to reverse the polarity on the foot pedal. Via setup ..mines a Yamaha pedal with no polarity switching..
Can't find anything in the manual...
Yamaha pedal will not work on a Casio. Casio uses a NO switch and Yamaha uses a NC switch and Casio has no built in polarity sensor.
Easiest solution is to buy an M-Audio SP-2 which does have a polarity switch and you can use it til hell freezes over and back :)
http://www.amazon.com/M-Audio-Susta...1?ie=UTF8&qid=1369500851&sr=8-1&keywords=sp-2
BTW, I own two of them and they are built like the proverbial brick outhouse :D
They're only $20 apiece... Spluge :D
..thanks for reply..ordered one from amazon.UK as I'm in England..
Not sure yet what to make of the wk7600...early days..
Seems good value for money but a bit 'lacking' in intros and fill ins ect when compare to my old Yamaha Psr3000....
sfz5
