WK6500 and Casio Chords
I'm not sure what you're asking. Can you clarify?
Casio Chords are used with the Auto-Accompaniment, so they don't work on the right-hand side of the keyboard, just on the left-hand side when you're using one of the auto-accompaniment rhythms.
If you're looking for an easy way to play chords on the right-hand side using a minimum number of fingers, you might investigate the Auto Harmonize feature.
sfz5
