XPS 10 Rhythm tempo
See page 29 of the Owner's Manual, in the bottom right corner of the page:
Adjusting the tempo
[SHIFT] + PAD [5]
Hold down the [SHIFT] button and press PAD [5] to access the TEMPO screen.
Use the VALUE [-] [+] buttons to adjust the value.
* Even if an audio file is selected, the tempo setting appears and you can change the value, but the tempo will not change. The tempo can be changed only for an internal rhythm pattern.
@Silas Sathyanandh asks:
I'm using XPS10 keyboard when I on audio pad after that going to bank that rhythm changing how can I stop that
