Yamaha DJX vs DJX II
I wanted to find a yamaha DJX, but it is nigh impossible using craigslist or ebay. More available is the DJX II. Is that one as good as the original, because I have not heard so good things about it. i would want a keyboard for techno, electronica and etc. Preferably MIDI compatible because I am into computer sound editing
Norway
DJX II:
The MIDI-functions will give you a headache. They're weird, and simply annoying. This keyboard is not any better than the original DJX, if not worse. You should go the the original DJX, however, if you can't find any sellers, you might wanna pick another keyboard. There's lots of other keyboards that work perfectly fine for techno and electronica.
<<Gratwhol>>
sfz5
