Yamaha MOFX6
Hello all, I’ve been using the Yamaha MOFX6 for a number of years. I’m having an issue where some of the performances I create are louder or lower volume than others. I have my volume level, set the same for each performance yet I’m still getting different levels of output. Anybody got any ideas of what I’m doing wrong?
I would start by looking at the volume of the individual voices of each performance. The preset voices do not all have equal volumes as each other; some preset voices are quieter or louder than others. This is not a bug; it's the way each voice was designed. If a given preset voice is quieter than you'd prefer, you can increase its volume to compensate. Note that I'm referring to the Channel Volume, not the Master Volume.
