- Joined
- Dec 21, 2017
- Messages
- 19
- Reaction score
- 0
So I finally got the editor app to work, but even with the app and the Paramater Guide there appears to be no way whatsoever to adjust the Arpeggiator speed. You can change the value from 1/16 to 1/8 notes etc but how do you change the tempo?
I changed the System tempo on the System menu, but the arpeggiator stays the same regardless.
Seriously? The Arpeggiator does't match the System tempo? The ability to change the arpeggiator speed is not something new, it's been pretty basic since the 90s! Either it's unable to perform this basic function, or the function is buried so deeply I can't find it anywhere. So I feel it necessary to ask- What exactly is wrong with the programmers at Roland? I'm sorry if this offends anyone, but this is insane!
(Edit) I found it thanks to the tutorial video. Tempo is under program edit- NOT under Arpeggio efit where it should be. This is an extremely sloppy bit of programming, and it's totally counter-intuitive, which is what I've come to expect from Roland.I don't understand this- their sounds are incredible but their interfaces are awful! Why is this? Does anyone have some insight into what goes on over at Roland?
