Fade out
Hello Technics KN5000 with Roland PK5 Bass Pedals.
My Fade out or Fade in automatically appear and turn on without me asking... could someone help me out what to do and also I'd like to make sure my Roland PK5 is set up correctly.
Thankyou very much.
Zolder.B
Thankyou very much.
The fade in function (if configured) starts with playing the keyboard or using the start/stop.The start/stop function van be replaced by the SZFC2 (4 switches you have to configure) or using a DAW
If you are using the PK5 as a midicontroller verify your CTRL channel on the PK5 and the KN5000
Good luck
drummerguycf
