Help needed with power supply pinout for PC2X/PC2R (PM0025-001)
Well then... DOCTOR @sunspot :)
I'm surprised you haven't asked over at
Just chock full of technical tips and techniques for troubleshooting electronic gear. :p
BTW, if your Kurzweil is using a switching supply you should know there is no way to measure out accurate voltages without a dummy load... Something not a lot of keyboardists out there keep in stock.
Actually if you're a doctor of applied physics, then I might assume you let the EE grad students do the actual screwdriver work. :D :D :D
I really want to go the other way around and check with the actual owner of the device.
True. But that will show as 15-15.8V on the AC output pins (instead of 14V). Easily distinguishable from the 9V on DC side that will show as ~0V AC on DVM.
That would be totally unethical since the synth is physically at the girlfriend`s :)
Hi Sunspot, attached pictuers come from my PC2X power supply; I think they should definitely answer your question.
Perfect. :) Thanks so much for all of your efforts in helping getting my PC2X form the attic to the living room.
drummerguycf
