- Joined
- Jun 6, 2014
- Messages
- 4,120
- Reaction score
- 1,741
Is an old Hammond organ an electronic keyboard?
MIDI is not a requirement in order for an instrument— be it an electronic keyboard, an acoustic keyboard, an electric guitar, an acoustic guitar, a drum set, a human voice, etc.— to be judged worthy of being called a “professional” musical instrument.
MIDI allows MIDI-enabled instruments to communicate data with each other and/or with computers or other MIDI-enabled devices (by which I mean non-instruments).
MIDI also allows MIDI-enabled instruments to play back MIDI data files which are used for song tracks, auto accompaniments, or even just patch setups or selection of preset voices/tones. Those particular uses do not necessarily require that the MIDI-enabled instrument have MIDI DIN or USB MIDI ports, since the MIDI files might be stored in the instrument’s internal memory or on a data storage device such as a USB flash drive or some type of data card.
But as extremely useful as MIDI is, every single musical instrument which is being used in a professional capacity does not need to be able to communicate data with each other or with a computer.
Now, if I had my druthers, I personally would want my electronic keyboards to be equipped with both MIDI DIN ports and USB MIDI ports, because I believe that both types have their uses.
But I would not deem an electronic keyboard or a MIDI controller to be a toy and unfit for professional use simply because it lacks MIDI DIN ports. And conversely, I would not deem it to be suitable for professional use simply because it has MIDI DIN ports. For example, the Yamaha PSR-E203 keyboard had MIDI DIN ports, but I would not be inclined to call it a suitable keyboard for a professional keyboardist.
Then again, a talented and creative professional musician can make music with just about anything that can make a sound— and an untalented and non-creative “musician” can make noise with just about any high-quality and expensive musical instrument. It certainly helps to have quality instruments, but it is not the instrument that makes the music— it is the musician who’s playing the instrument.
