Problem in FL studio 12
Like i have connected my keyboard to computer and rest setup is done to use FL studio
I have used FL studio to make songs but after making my first track i noticed that it was a free trial version..
So what should i do now if i don't want to buy FL studio
Can i very the full FL studio for free?
I assume FL studio is one of those programs that allows you to use the trial version for a short while to give you a feel for it, but then requires you to stump up the $$$ to continue to use.
So I think you're out of luck if you want to keep using FL studio, and aren't keen on paying for it.
Audacity is a good free DAW which you can record with - maybe give that a shot?
