Style convertor kn 6500
friends, does anyone still have the style convertor for the kn 6500 ?
I would be happy, to have one.
john
Quebec,Canada
Hi have the EMC XT,I Never use for the midi convert because I dont know how
The styles convert from another brand is OK ?
England
Hi Rikki - long time no speak - yes it is the same disk that was produced for the KN5000 and if you have one then it works after a fashion. I much prefer EMC Styleworks which provides excellent results.
N.S.W. Australia
Hi Roger, wow , you remember me. . It would have to be 15 to 20 years. No, actually I haven’t had a technics for many, many , years. Reason I was asking, if I remember correctly, those conversion disks couldn’t be copied as a back up on pc? I actually had a friend with a Mac and got him to try it. It worked.
I also had EMC , but my old pc died, and I couldn’t get the codes again. EMC seems to have disappeared?
You still have your Technics?
best wishes
Rikki
Similar Threads
JCGlines
