Sustain pedal for my KN-920.
I still use an KN-920 keyboard I love the old sound what is in it, there is on the back an sustain padel connection, is this universal ? Can I use also other brand pedal with an 6,4mm plug ?
yes, get one that has a open/closed polarity switch, some keyboards require nornally open and some require normally closed, meaning that the wrong pedal will work backwards. if you purchase one with a polarity switch and it works backwards simply flip the switch to have it work correctly
Thank you, I will order one with a switch.
drummerguycf
